APX Selecting ASTRO TG Using Keypad (APX 8000)
Is there a way to program ASTRO Talkgroup Lists so that you can enter the TG ID on the radio keypad to select it? Right now, even though there are no "numbers" in the list view, I can search using the numerical sequence of the TG's placement in the list.
No, you need to enter in the groups you want into a talkgroup list.
I have them in my Talkgroups list, but they don't have numbers assigned to then in the list view. I want to be able to select by TG ID, if possible. E.g., 1234 on the keypay for Talkgroup 1234.
I was reading through the user guide and I don't think it's possible but I wanted to ask here with more experienced users.
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
Consider the operational needs that these systems are built around. No system administrator wants any typical user to be able to just select any talkgroup at will. Your agency or department restricts you to the list of talkgroups you have business on, and you don't get to go talk to the dog catcher on his talkgroup when things are slow in your department.
Imagine the chaos that would occur if every user could pick any system talkgroup at will. Because some people would end up on talkgroups they have no business being on.
GTR8000
NY/NJ Database Guy
BEE00
OP is referring to the conventional ASTRO talkgroup list, which does not require a trunked system key to modify in CPS (because it's not trunking, duh). Also, he doesn't want to directly enter a TGID into the radio via the keypad, he wanted to be able to select a pre-defined talkgroup by entering its TGID as a "quick key".
Anyway, @mikewazowski already answered the question. No, it's not possible. You select the predefined talkgroup by pressing the TGRP button/menu softkey, then select from a list.
