Selecting Systems for Starcom / Sentinel
greggk
Palatine, IL.
Its another GREAT day in Cook County!
I am still on pretty shaky ground learning this new 436. And, just when things are looking up...another issue.
I am attempting to create a system / list for NWCD / FIRE.
In Sentinel, selecting the database from the left side of the screen, I select:
--Illinois
--Cook Country
--State Wide
--Starcomm 21 (State wide)
-- Cook County- Northwest Central Dispatch.
So far, so good.
Then, when I click on COOK COUNTY, NWCD, and select Append to favorites list, it appends ALL systems that all on the Starcomm system.
Literally everything in the state under that heading of Starcomm21 shows up on the list. I suppose I could go thru each unwanted system individually and remove them, but it would take forever.
Am I missing anything here? Any help is appreciated. Thanks
Greg
RoninJoliet
ILL
I don,t have that series of scanner yet, what u need to do is program in T149-NWCD, that's the only tower I think there using.....CC ch-851.5375
greggk
Palatine, IL.
Thanks. The issue is when I select a channel to load into the sentinel software, it creates a favorites list with all the other sites attached to starcom. I found the only way to fix it is to load what you want, then go back and delete everything else manually.
Greg
