A bias tee or voltage inserter is really easy to make for HF. I can't find a good diagram with component values so I'll try to describe one.
Start with a small box, preferably metal where you can mount two RF connectors opposing each other maybe an inch or two apart with their back sides facing each other. I use cast aluminum boxes from Hammond or Bud that are about 4" long X 1.5" high and maybe 1.5" wide. Bridge the center pins of the connector with a .01uf disc cap and the voltage will depend on if your receiving or transmitting and the power level. You can't go wrong with a 1kV rated disc cap or several smaller value caps in parallel to add up to about .01uf. For receiving only, a 100v rating is fine.
Then solder a small inductor between about 75uh and 100uh to one of the connector center pins with the shortest lead length you can make and at a right angle away from the cap that bridges the two connectors. The inductor needs a current rating of a least what your relay is expected to draw. I use JW Miller model 5250 rated at 100uh at 2A because I got a case of them cheap on Ebay. On the other end of the inductor solder a .01uf disc bypass cap from the unused inductor lead to the metal box (ground) using the shortest lead lengths you can.
Finally, install whatever kind of power connector or screw terminal you want on the box to feed in your voltage to the inductor/bypass cap junction. Better yet, try to find a .01uf feed through capacitor, the kind that threads into a metal box and has an input and output connection and that can be both your inductor bypass cap and power connector. Make a second box just like the first.
The connector that has the inductor attached will be where your feedline connects at each end and that's where the power will be injected or pulled out of the coax. The connector with no inductor will be what connects to your radio(s) on one end and the rest of your antenna switching stuff at the far end. The cap(s) between the connectors block your inserted voltage from getting to your equipment or antenna. The inductor with bypass cap provides a low impedance path for the voltage to get into the coax while providing a high impedance to the RF so it doesn't flow back into your power supply and so the power supply doesn't load down the RF path.
I've made lots of bias tee's for HF through UHF and use them to feed power to remote HF antenna tuners, mast mounted preamps, etc. A bias tee as described will pass AC or DC voltages up to near what the disc caps are rated for. If you can't find the parts locally they are all available on Ebay cheap.
prcguy
No, HF antennas.
I hadn't thought about running it up the coax. But that's only D/C right?
So 100' and 5vdc isn't too far? Seems when I built our last house, I had problems running 12vdc to all the outlets, so just assumed 5vdc would be even harder to get that far.
Thanks for the tip on the ferrite core.
