Sensitive setup for hearing NOAA weather radio
KB2GOM
Rensselaer County New York
I was fooling around with radios this AM, trying to figure out which setup would hear the most NOAA weather radio stations (NWR) from my location just east of Troy, NY.
On a whim, I attached a Comet W100RX telescoping metal antenna to my Icom R6. This antenna is supposed to cover from 25-1300 MHz and extends from 8 inches to 40 inches. I tuned to a loud weather radio station and began adjusting the length of the antenna to maximize the number of bars on the signal strength meter. Twenty inches turned out to be optimal.
Then I turned the selector knob to see how many NWR channels I could hear. To my surprise, I could hear a signal on all 7, and if I waved the antenna around to different angles, I could hear a copy-able signal on all 7. Wow. The R6 will also do weather alert, but not on a sophisticated level with SAME codes and selectable hazards.
By contrast, my SDS200 attached to an off-center-fed dipole -- Homebrewed Off-Center Fed Dipole - The RadioReference Wiki -- hears 5 channels (and has very sophisticated weather alert functions.) My Midland WR120 has similarly sophisticated alert capabilities and can hear 4 channels at the same location.
FWIW, I was really surprised at the sensitivity of the R6/W100RX combo. If you like to DX NWR stations like I do, it might be worth a try.
dlwtrunked
Keep in mind that distant stations come and go with propagation . Here about half the time I hear all 7 frequencies and about half the time only 2 or 3. So no matter what you do, propagation will sometimes get the upper hand.
eagle2046
Eugene, Oregon
I haven't been able to recieve NOAA weather broadcasts for a while now. I live in Oregon and usually get the broadcast on 162.400 mHz. I tried to recieve on 6 different radios and same result...seems like a dead carrier with no voice broadcast. Was wondering if that NOAA site is down. Friends in other parts of the country are recieving broadcasts ok. Thanks for any information.
I am a lineman for the county.
NOAA is already aware and has it showing on their outage page:
You can view and report outages on this page:
JustinWHT
Keep in mind that distant stations come and go with propagation.
Posted in DSLreports WISP two years ago ..
I use the VHF (162 MHz) NOAA weather radio transmitters to check out [VHF] propagation.
Usually Fort Worth comes in strong, and Dallas 35 miles east almost equally as strong. On cool weather nights I can hear all seven stations, some as far out as 120 miles.
But lately during the hot 100°+ days (I'm Centigrade challenged so convert yourself), Fort Worth is sketchy 10 miles out and Dallas buried in the noise. At the moment, at midnight at 95°, Fort Worth is noisy.
