Sentinal install and .NET Framework
HogDriver
Blackford Co. Indiana
Trying to install Sentinal on windows 10 computer. It tells me I need .Net Framework 2.0. I have 4.6.2 installed. What's the deal???
Sent from my iPad using Tapatalk
RFBOSS
In Windows 10 check that that it is enabled. Windows 10 may go the internet for some files, just follow the prompts.
This would be my first step.
phask
zanesville
They are not cumulative - you might need several versions
RFBOSS
Checking the boxes for Net Framework 3.5 should cause Windows 10 to see if it has the necessary files to enable 2.0 through 3.5 and if not go to the internet and download and install the files.
The process should enable 2.0 through 3.5.
HogDriver
That fixed it! Thanks for the info.
