Thanks Brian. You are correct that you can right click and append systems, departments, and individual channels. On a trunked system the DB also shows all the towers (sites) for the trunked system. I am trying to append a tower from the DB to the FL (after the FL had already been created).
That's what I'm talking about. If you just a append that whole system / sites to a new favorites list, you can copy the site you want from that new favorites list and then go into the edit mode on the favorites list sites you're interested in adding the data to, and then you can taste it there. Or you can just manually get the information off of radio reference and add it as a new site in the software also.
I know it's a pain in the butt to have to copy something, closeout editing that favorites list, open the new favorites list to edit, and do all of those extra steps involved to accomplish something that should be a lot easier. I really wish that Uniden would update the software and make it easy to just copy or drag and drop data. But since you can't have two favorites lists opened at the same time while you're editing them, there's just no way to do it other than the longer drawn-out way
There should be a plus button or something like that when you're looking at the sites inside of Sentinel. And I don't know if you can copy anything off of the National Database and paste it but that would be worth at also. If it's just one site you're trying to add, that data they should be on the radio reference website where you can easily add it in manually rather than trying to drag it over buy appending it having to create a new favorites list to copy from. And there may be some other way that I haven't come across just yet?
I had to add a new site a few months back and I did it the way that I'm talkin about. And then I copied all of the sites I had correctly entered and went through and manually pasted the data into other favorites lists and systems using the same correct sites information. It was more work than it should have been but it did work
I guess an easier way of saying what I'm trying to say is that if you create a new favorites list that has all of the sites you need, you can just copy and paste from it and then delete that favorites list. Just make sure that all the sites are there in the ones you want to lock out or do anything extra with are set up the way you want them.
Brian (COMMSCAN)
Sent from my SAMSUNG-SM-G930A using Tapatalk
