I cannot get the sentinel software to work on my windows 7 computer. The software that came with the home patrol crashes and I downloaded the latest version and it too crashes immediately at startup. Can anyone help me with this?
You have the Microsoft .NET framework ?
Well it cant be the version 4 ,it dont work!
Use the one it came with in the zip file or it Wont work.(version 2 is what it comes with)
If it still doesnt work,run a spyware/antivirus scan with AVG free,if that doesnt work your windows is corrupt.
Also if its a DELL dont plug HP-1 into front ports.
If you are using a USB hub,connect it to the computer first.
Hit us back if still no good.
HomePatrol is where you get the software.
if you get errors,post what they say.
I plug my HP1 into the front USB ports on my Dell and it works just fine.
Probably a corrupted Windows 7 install. Version 8 on the way and they still haven't got it right.
my sentinel stopped about a month ago, message says sentinel stopped working.
Window trouble shooting says program not compatible I tried reinstalling and windows says not enough memory. UPMAN is there patch to fix this?
+1...Same installs here (and only the Win 7 is fairly clean....the Vista is on it's third year and the XP laptop on the ninth or tenth ..)What would he fix? You gave absolutely no info. I personally have it running on an XP, a Vista and a Win 7 machine, are you on DOS 3.1?
sorry I thought I was following a tread about windows seven and sentinel problems .I have widows seven and sentinel worked for three months then stopped. I take it from the discussion others are seeing this also. I am not the greatest computer smart person and would like some help.
<snip>
Go into Programs under control panel and run the Repair option after you select Home Patrol Sentinel and see if that fixes things. If not, then do the uninstall/reinstall thing but download the latest Sentinel version from the Uniden site and use that for the new install.
Does it produce this error window as soon as you open Sentinel or does it wait until you try and do something with Sentinel?
