Sentinel DMR assistance for BCD 466HP Abbotsford
Heidi750
Kimberley, BC
Once again I have to turn to the group to find an answer ...
I am still using my BCD436HP, Looking into DMR for Abbotsford, BC, and having a little trouble with the Lingo.
In RR for Abbotsford the listing I'm looking at is:
Freq: 460.1625 Tone: CC10, TG*, SL1
I get the Freq, and Slot 1 but seem to be lost for the other 2.
No where can I find a place in the Sentinel Software for the Color Code 10 ??
2nd if I enter anything besides a number in the TG slot ... it rejects it??
(I have seen 1 in the slot)
I have seen TG* (wild card) in the "Channel Name ... but I'm sure it doesn't go there.
So what do I use for a wild card and what do I put in the TGID slot??? (or does the 436 use Wild Cards?)
How do I get the TG# to show?
Thanks Again to the Group
mciupa
Canadian Database Admin
Moderator
You need to have the entry in a Favourite List. From there you can make some modifications.
For Colour Code 10, Edit the Favourite List Abbotsford is in. Under Audio Options it will likely be marked as SEARCH and ALL. Other options are grayed out. If you select Digital you now have the ability to select Colour Codes with the pull down menu. Save that entry. WRITE TO SCANNER to save your modification.
With the talkgroup, I usually push HOLD when it is active then ENTER.
