Sentinel for BCDx36HP and SDSx00 2.01.01 Available
TxScanner
Downloaded and good to go, now, just need the scanner i preordered :}
Sent from my iPad Pro using Tapatalk Pro
trentbob
Silent Key W3BUX
Bucks County, PA
Now that I have updated filter options on the SDS 100 can someone direct me to where I can find out what those options mean and what they do? Thanks.
teknishun
Alvin, Texas
And also tell us what does "HPF" stand for and what does it do? The options are auto, normal or inverted.
msingewald
Norwalk, CT
That doesn't really describe what HPF is. I presume it is High Pass Filter? What is the filter frequency, something fixed or just passes everything above and including the tuned frequency? Does inverted mean Low Pass Filter? Interested to know what it is doing.
maus92
OCMD
Thanks UpMan for ushering through timely firmware updates.
D
DaveNF2G
Guest
A full description of the new filter settings was posted in the Uniden Scanners group on Facebook.
mule1075
Washington Pennsylvania
pfd461
Hello people. I see Uniden has a new version 2.01.01 of Sentinal available. My current version is 2.00 which I downloaded when I bought my SDS100. Question if you put the new version in you don’t lose your all your data that you had in the previous version do you? Also I guess you can’t download this new version from Sentinal can you?
Thunder Bay ON
No data loss.
Open Sentinel
Click on Update>Update Master Database
Sentinel will advise that database can’t be updated until new version of Sentinel is installed.
Sentinel will shutdown and should then direct you to the Sentinel download page.
Download the new version and install.
The download takes longer than the install itself.
pfd461
Thank you very much. I will give this a try.
pfd461
TOM I just thought I should tell you I did exactly what you said and everything fell right into place, version 201.01 was installed again thank you for the advice.
Thunder Bay ON
Just noticed another update today. Fixes a bug introduced with with the previous mentioned update. You’ll have to update again.
