Sentinel: Found minor (though annoying) bug
Bigfootbuilt
On the Edit Profile window in the Custom Scan tab, it is impossible to save the "Custom 9" Bank Status to "OFF" position. You can switch it to off, but when you save the profile it just switches back to "ON".
kma371
what version of sentinel are you using? working ok for me on BCDX36HP version 1.07 (revision 05)
i noticed when you select it to "off" in the pull down menu, you must hit enter, then close the window and save. if you just select it to "off" and close the window and save, it will reappear. try that and see if it works.
Bigfootbuilt
Exact version I'm using. It is for the BCD536HP. Once I switch it to "off" then close the window so I can save the profile, open the window again and it is back "on". No other custom bank does this except 9.
kma371
Did you try what I suggested. Switch it to off. Then hit enter. Then close the window and save profile.
