iMONITOR
Silent Key
Is there a way to get Sentinel to import/display the "Description" field in place of the "Alpha Tag" field? Proscan an Butel's software allow for this.
Sentinel already uses the Description field instead of the Alpha Tag field. I believe you've got it reversed, and that you want the Alpha Tag instead of Description.
In any event, it's highly unlikely to get changed by Uniden. Their whole point of using the description field with the models that rely on Sentinel (HP, x36HP, SDS) is that the screen also displays the Department name from the database right above the Description, which creates a flow of information down the screen.
"Countywide Fire Dispatch" is the Description field for 154.130, vs "Macomb Fire 1" for the Alpha Tag. If you wish to use/import the Alpha Tag instead, you'll need to use third party software, as others have correctly noted.
I am 100% positive. I loaded up the full database using one of the zip codes in Macomb County and held on that channel. That is directly from Sentinel as shown on a 536.Are you sure that wasn't programmed with ProScan instead of Sentinel?
Hmm, you've got me curious now what you're seeing. What model scanner(s) are we dealing with here?Maybe I'm confused. I do know the differnce between Alpha-Tag and Description, but regarding Sentinel I could be mistaken. I've been spending too much time playing with my AOR DV1 for several days.![]()
For example, using the existing programming for Los Angeles County, Many of the county fire channels just show up as "tactical" What good is that?
That's frustrating. Maybe the other way to tackle this is to see if RR DB admins will update it to rename the description to the Alpha tag, since the Descriptions are not unique.
Those descriptions should have more detailed info as to which tactical channel it is.That's the problem right there. I know what the channel is used for, but I don't know which channel I'm listening to. It's foolish of Uniden not to change this.
