If you see the see the Pottawattamie Co favorites list in the left colimn of Sentinel, proceed to the following instructions. If you had problems importing the favorites list, please let me know. You can create different profiles for yourself and others for programming scanners. Click on the File tab and New. Name it with something like your name and click OK. Go to the Edit tab and Edit Profile. If the boxes for Monitor Full Database or Monitor Search with Scan are checked, click on the box to remove the check mark. Click on Pottawattamie Co to highlight it. Above the favorites list, you will see Monitor On and Off and Download On and Off. Click On for Monitor. That will turn on both Download and Monitor. Download means that the favorites list will sent to the scanner. If Monitor is not ON, it will be locked out in the scanner. You should see the Quick Key of 0 in the next column to the right. Close the Profile Editor by clicking on the X at the upper right corner. After closing the editor, you will see (Profile Name) Updated at the top of the screen. Click on the File tab and Save. Updated will disappear. Turn the scanner on and connect you scanner to the computer with the USB cable. Press E. USB Mass Storage will be displayed on the scanner screen. Go to the Scanner tab and Write to Scanner. You should see the disk drive, Uniden BCD536HP, and the electronic serial number in the window. Check the box to Erase Favorites Lists on Scanner. Click OK. Click OK again in the warning box to write to the scanner. Once the writing is completed, click OK. Dismount the scanner before disconnecting the cable. At this time, you should be able to toggle the favorites list on and off by pressing 0 on the keypad. The scanner should be working at this point with the antenna connected.
