Sentinel programming
govermentcheese
Niles Michigan 49120
Hello are frms, Murs, grms frequencies in Sentinel programming. Can I install them into my sds-100.. I am looking to make favorite quick keys. I just got an SDS -100 a few days ago. I haven't figured out and understand favorite and system and department keys. Thanks..
RMason
Colorado / Mississippi
Hello are frms,Murs,grms frequencies in centinal programming. Can I install them into my sds-100.. I am looking to make favorite quick keys. I just got an SDS -100 a few days ago. I haven't figured out and understand favorite and system and department keys. Thanks..
FRS, MURS, and GMRS are included in the Nationwide systems.
In Sentinel, go to the Database section and select USA to expand the list of states.
- Select your state to expand the list of Counties.​
- Select your county to expand.​
- Select the Nationwide folder.​
Among the 'systems' in the Nationwide folder are GMRS, FRS, and MURS.
govermentcheese
Does anyone know .When in the program when you click edit profile and then try to change tone alerts when I click on them it does not change. Can I change tone alerts in the sentinel programing..
hiegtx
Dallas, TX
You cannot change the tone alerts, alert light settings, and other items using “Edit Profile”.Edit Profile is where you set, among other things, which Favorites List to be monitored and/or downloaded when writing to the scanner.You can also set or adjust your range settings via this edit.
Those items (alert tones and LED colorscan be edited, added, and otherwise changed via Edit Favorites List. Select Edit Favorites then choose a list where you want to make changes in alert lights and tones, as well as any other edits or additions to Systems, Departments, and Sutes, and channels within a list.
