Sentinel: Renaming "Custom" Service Types
mfn002
Bryan, Texas
In Sentinel, I've noticed that there are several "Custom" service tags. Is there any way to rename these?
yes
On the radio you just go to edit custom and select name E is enter and erase,knob changes letters and 6 moves the cursor forward.I looked at the sentinel,I dont see the search options in there.
mfn002
Bryan, Texas
Is there any way to do this in Sentinel, or can you only do it on the scanner?
phask
KZZV - SE Ohio
Do you mean
#1 change the Custom1 service type itself?
#2 Or change the service type on a line item?
You can't do #1 - can #2 in Sentinel
fxdscon
¯\_(ツ)_/¯
The names of the service types can not be changed.... either in the scanner, or in Sentinel.
As phask notes, you can change the service type assigned to an agency, but you have to stick with the service type names provided.
mfn002
Bryan, Texas
Thanks. That answers my question.
Custom Service NAMES can be changed my 536Hp has :
1 is 144MHZ search 145-147.995 range
2 is 220MHZ search 223-224.995
3 is 440MHZ search 440-449.995
is what I entered on the scanner.
The service TYPES like FIRE DISPATCH can not be changed,but the custom ones CAN be changed like Custom 1,2,3 etc. But THAT has nothing to do with search .....
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
The OP never talked about search at all.
And the "custom ones" cannot be changed. You can't make "Custom 1" turn into "Drag Racing" or anything like that.
Gilligan
Hagerstown, MD
Put my vote down for this to be changed in a future firmware release. We should be able to change these custom service tags to whatever we like, and in my opinion, we should have between 5 and 10 of them to use for our own purposes... Remember that these are potentially visible for every single transmission that comes across the screen of our scanner, so it makes sense to be able to utilize this functionality in a strong way.
ofd8001
Louisville, KY
If I was a betting guy, re-naming Custom Service types may present some unintended consequences. I imagine that there are some specific rules in the database controlling the number of characters in the field that contains Service Types.
For example, the field may be limited to 15 characters. If someone re-names "Custom 1" to "My Local Fire Departments" which is about 25 characters, it might give the scanner a big headache. Kinda like putting 10 pounds in a 5 pound bag.
freqhopping
Lo Co VA/ FM19
The service type tags don't exist as text in the favorite list files. There are numbers that correspond to each service type. The software and scanner read that number and display the corresponding text that is programmed in the software and scanner.
Some of these are:
2=Law Dispatch
7= Law Tac
23=Law Talk
26=Transportation
30=Military
208=Custom 1
209=Custom 2
210=Custom 3
211=Custom 4
212=Custom 5
213=Custom 6
214=Custom 7
215=Custom 8
I don't see them changing the software and firmware to make these custom numbers show up as something different.
JoeyC
Senior Member
San Diego, CA
It wouldn't do any good to change a service type. They are controlled by the
RadioReference database.
Not true.
All service types assigned by RR can be changed by the user if desired. Besides that, it is not that people want to change the RR issued service type more than they want to assign Custom service types to use as customized filters.
