I've noticed when using Sentinel software on my SDS100 the software doesn't allow the P-Ch setting to be changed. Is this by design and P-Ch can only be done on the radio itself? Any thoughts or help are appreciated.
Thank you.
Thank you.
You can set Priority for a given channel in Sentinel. It is the far right column of the edit menu. Depending on your PC's display setting, you may need to use the scroll bar at the bottom of the edit window to see it.I've noticed when using Sentinel software on my SDS100 the software doesn't allow the P-Ch setting to be changed. Is this by design and P-Ch can only be done on the radio itself? Any thoughts or help are appreciated.
Thank you.
