Sentinel Software & ARC-X Software
DSC45
Central Jersey
A question regarding installing Sentinel Software & ARC-X Software on my PC using Windows 7.
Can both programs be installed without interfering with each other?
I currently have a BCD536HP and maybe be purchasing a BCD996XT.
Thank you.
markbart
Spencer IN
Thank you.
I run Sentinel and ARC-500 on my Windows 7 machine. Both work great.
ofd8001
Louisville, KY
I'm using both. As noted above, one does some things better than the other and vice versa.
The thing I have to remember is to keep my files synchronized, otherwise it can be frustrating when things don't match. So if I write to the scanner in ARC, I'll read the scanner with Sentinel (a "files don't match" message will appear, just overwrite what is in Sentinel). The reverse is true too - if I write with Sentinel, I'll read with ARC.
