Is Sentinel Software a database program or is it a program to control the scanner?
It's software to program certain Uniden scannersIs Sentinel Software a database program
It's a program to manage and update certain Uniden scanners.Is Sentinel Software a database program or is it a program to control the scanner?
Favorites lists are not updated when you update the database. The database is updated in your computer only.. The database in the scanner is not updated until you write to the scanner.
So when I Update Master Database it pulls the USA database from Radio Reference? If so, updating it weekly will keep Sentinel up to date with frequencies?
I am just trying to figure out if when I updated the database in Sentinel and I select down to the county I am in, are all the frequencies that are list in the RR database there?
When you Update Master Database, it pulls it from the Uniden site FTP site. Uniden pulls the data from RadioReference once a week. Updating once a week will update the database, but not your favorites. You have to copy the data from the database to make updates to favorites. Or you could manually update the favorites. For small changes (e.g. adding talk groups to a trunked system) is usually the best approach. Once you are finished updating your favorites, you will need to write it to the scanner.
You can download and use the Sentinel software before you purchase a scanner and try it out. You don't need to actually have a scanner to experiment with the software.
Just download the version of Sentinel for which ever scanner you are interested in and try it out.
Every few days (at least once a week), look at your state on the initial database page.thank you, this is what I thought and you confirmed.
They missed a couple of weeks. It was already discussed in the forumsI show the last Uniden Database Version update on 4-26-2020.
