BCD536HP: Serial Driver Issues
lost_in_maine
Western Maine Mountains
I am having a problem with the Serial Driver on my 536...While scanning it sometimes just goes to sleep, and I notice radio is quiet...Display shows out of nowhere that it is USB storage Mode....
Com Port (7) always shows in Device as enabled when loaded
I am using the front port for virtual control to ProScan...
I am running Windows 7X64 on my Desktop, I have 10 USB ports, so doubt it is a USB power issue
Machine is a beast so know it isn't my PC
When it disconnects, My only thing I find is this in the Windows Event logs:
The driver \Driver\WUDFRd failed to load for the device WpdBusEnumRoot\UMB\2&37c186b&0&STORAGE#VOLUME#_??_USBSTOR#DISK&VEN_UNIDEN&PROD_BCD536HP&REV_1.00#0000000000001&0#.
It will be already running, and just goes off to la la land
eaf1956
Evansville, IN
The only way I found around the front port problem is to use the rear port with PROSCAN.
joeuser
The Wretched
North Central Kansas
Have you gone deeper into the USB, through Device Manager, properties... Look for a Power Management tab... See if Allow computer to turn off device to save power is toggled
lost_in_maine
Yes, I have USB Selective Suspend disabled globally in Windows for all usb devices through advanced power setup..Be nice to even get a USB 3.0 driver!
fxdscon
¯\_(ツ)_/¯
lost_in_maine
lost_in_maine
lost_in_maine
Drivers are needed for that also.
Yes, but anything I've bought with FTDI chip, drivers are not buggy as some other vendors...if I went the root with a PCI-e serial card, just more things can go wrong
I just downloaded the latest driver, and just as I thought, there are x64 drivers..which I try to always use, and I steer clear of anything that's only 32 bit..
