There appears to be a ghost in my machine?! As of a few days ago, my feed has just began to disconnect and re-connect to the server on its own. The broadcast always stays running, but I get an "error" message on the status screen that there is a disconnect with the server. This is a dedicated laptop that is only used for my scanner feed. I've disconnected and re-booted everything I can think of with negative results. When the feed is online and I attempt to listen from another computer, I get about 7-9 seconds of feed audio then it quits and disconnects. Is anyone else experincing or has experinced this issue? Any input would be appreciated.
