Setting PSR 800 clock
catken
Just received my scanner and I can not figure out how to set time and date. Please help.
railfanguy
You can also set the clock via the software while the radio is connected to the computer. I think the command is under the File menu (away from radio right now). The radio clock is automatically set to computer clock time.
catken
What did I do wrong
After setting the clock; thanks by the way, I went to the library and installed the info county ect.and police for scan list 001 and imported it. Go to scan and it says nothing to scan. Whats up.
mciupa
Moderator
*Delete* - Post merging has filled in details left out prior to my original post and bumped me down to post #6.
catken
Thanks I knew I should have just stayed with playing with tinker toys and legos.
lebrunmn
Curmudgeon
Hamphire County, WV
Scanlist Set?
catken-
I think I did this the first time I tried to program my 800...
Make sure that the system is in at least one scanlist set... please take a look at the attached image. By default, the software puts all scanLISTS in the first scanlist SET, but I played around with the software and disabled it, so I had a similar experience.
Hope this solves your problem. If not, there are lots of folks with PSR-800 experience here.
