Setting up a UHF TRUNK SYSTEM
midnightcaller
Lake Stevens
Iam going to set up a UHF trunk system for this weekend
the trunk system has 2 freqs,2 for TX and 2 for RX for a total of 4 freqs per sight
1st group of freqs is channel 1 for TX and the 2nd group of freqs is for RX
Is this a EDAC system or a LTR? would I need a offset?
Dave
KT4HX
Spotsylvania County, Va
You haven't given much info. Is this some system in Snohomish County or elsewhere? Have you looked the system up in the RR Database - as that will likely answer your questions? It's good to give as much info as you can, that way everyone is on the same page when trying to respond.
midnightcaller
Lake Stevens
It is not in the Data base it is a privite trunk system with UHF channels I have it set up has a LTR. I do see talk groups pop up but no voice Each sight has 4 freqs a 2 for TX and 2 for RX they are 5 megs apart..
captclint
Mountaintop, PA
It would very unlikely any trunked sys would have only 2 freq's. Only the output repeater freq's count. So it is more likely that there are other frequencies from another call sign or even a different location. Most systems have at least 5 Rptr freq's. If you have a Uniden, you will not hear any voice when the TGID's are displayed unless the frequencies are entered into the bank in the exact order of the LCN. However, you can just SIT on one of the channels in the ID seach mode and you can see the ID's along with the voice.
That is the easy part. Since you think it is an LTR, suggest you look at the FAQ:
http://wiki.radioreference.com/index.php/Mapping_an_LTR_System
This should help you find additional feq's and eventually put them in the correct order.
