hmm, i guess im going to have to play with it. i can't get it to stay on one precint's channel unless i hit the PSE button. i basically copied the attached pic for the precints/channels i wanted to listen to.
The problem with using the pause button on a trunked system is that your precinct's transmissions will CHANGE FREQUENCY each time a repeater drops. That is there will be activity on your precinct's talk group. Once the exchanges stop, the repeater stops transmitting, the talk group goes back into the system controller's shuffle until someone in that talk group keys up. The controller automatically ties everyone in that group to another frequency.
For that reason, if you want to listen to a specific talk group, you must press and hold the TRUNK key until you see "ID HOLD" on your screen. If you press the pause (PSE) button, it will send the scanner to the system control channel. This is assuming you have everything programmed correctly. It is if:
- you have at least all control channels entered in your scanner.
- you have the bank AND all system channels in Motorola (MOT) mode, not FM.
- you have you precinct(s) talk group(s) entered. The talk group listing for Baltimore County is in the RRDB, the info you need to enter is in the column labeled "DEC" . For example, If you want to listen to Parkville Dispatch, you need to enter "1840" in your TG list.
- to ensure you only hear what you want to hear, close the bank. If there are any TG's you only want to hear on an occaisional basis, enter the TG as you would. If there's a time you don't want to hear that TG, you can lock it out.
did you get a manual with the unit? If not you can see/download the manual here:
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000527_PM_EN.pdf
Hope this clears things up for you.
