Setting up to Broadcast from UV-82c
tischa01
I am looking to start broadcasting and was looking at using UV-82c to do this. I was wondering if there was a cable that I can connect the radio to my audio card. Can I plug directly into the 2.5 or 3.5mm jack directly or is there a special cable needed.
jonwienke
More Info Coming Soon!
VA
Broadcasting what?
You'll probably have to make your own cable. You'll need to be able to make the proper connection to key the radio, as well as attenuate the line- or speaker-level signal down to mic level so you don't fry the audio input.
Don't try this at home unless you know your way around a schematic and are handy with a soldering iron.
12dbsinad
If you would go into a little more detail you would receive better advise. Are you trying to rebroadcast scanner audio? There is more to know then just buying a UV-82 and start transmitting.
tischa01
I would be broadcasting the audio online as a scanner feed. I would only need an audio out to connect to my computer.
KD8DVR
Columbus, Ohio
Uh.
You know this is likely illegal? You know to transmit on this radio, you need a license? What frequencies do you want to use?
What are in the radio from the factory, are test frequencies. Using them would interfere with licensed users on those frequencies.
Users would re program them to what they are licensed to operate on.
There are legal ways to do what you want to do.
This thread could go wrong in so many ways.
AntiSquid Disclaimer: All posted content is personal opinion only and may not imply fact or accusation.
12dbsinad
Uh.
He stated he wants to feed audio to a computer as a "scanner", not transmit. His original post was kind of vague.
With that being said, he should be able to so this from the accessory connector.
jonwienke
VA
Unless you are only monitoring a few channels, like less than 10, using a Baofeng as a scanner is a really dumb idea.
12dbsinad
I'll add to this, since it sounds like he doesn't own one. It is because it scans PAINFULLY SLOW, compared to a regular scanner. If you are just concerned about one, or a few channels, they work OK.
tischa01
I have had a UV-82C before and was looking to use them for security operations at special events instead of buying a bunch more XPR-3500 which we are using. Somehow we ended up going with all XPR-3500 radios for security operations however we only use UHF. When we work event a lot of times we are working closely with local Law Enforcement and need to talk to them on VHF. Most of the time they give us a radio to use and one of my officers are carrying 2 radios. Other times during large events they can not spare a radio for us to use and we end up going without since most officers do not want to carry 2 radios. We have worked on UTac Channels to communicate better with Law Enforcement Dispatch but we still are not able to hear other traffic that could assist in doing the job better
So here was my Idea. I have looked at Using VOIP systems to broadcast scanner frequencies online to use with Zello or just to broadcast for everyone to hear and also retransmit on a 2nd UHF channel (That I have a license for) for officers in the field to be able to hear and respond to. The reason I want it online is I have a License to transmit on my UHF frequencies anywhere in the US and have Security Operations in 2 different parts of the state with only 1 Dispatch Center. So would like to be able to do more dispatch via radio than with a VOIP system and having dispatch and officers be able to here the right traffic regardless of where they are at.
The reason I thought about the UV-82C was it was cheap and I could use it as "Scanner" to listen and broadcast the feed online as well as use for operations if needed to be since it is FCC Compliant with a business license and not a HAM.
I was looking to have 1 computer dedicated to Radios and connect several UV-82 each with a different channel on them and broadcast each channel separately.
Hope this give you some more info on what I'm trying to do.
