Hello radioreference,
I'm new to the community having gotten into the hobby within the last year or so. I've recently begun programming my FT5DR and thought I had it all done, but it seems when I record audio (from a receiving frequency) no file is being created in LOG when I go in there to play it back. I've updated the firmware to 1.1, formatted the SD card, installed ADMS-14 on a computer and saved that on to the card and then read that info the back to the handheld. (As per instruction, I did write to SD card before using ADMS). I saw in ADMS where I can set up all the memory banks etc, but I didn't see any specific instruction as to setting up folders where audio files save to so I assumed that was already in place.
When i go to LOG, I do see Voice/Picture/Etc but there is nothing in the folder. I've watched a bunch of vids which show that when you click on the Voice folder after recording some audio, you should see the audio file you created, but when I click on LOG after a recording, it doesn't take me into a folder... it takes me back to the menu where in the top right corner (beneath the battery bar) I'll see 004 (or 001 depending which channel I was recording) with the middle zero flashing.
Anyone with some experience programming these handhelds know what I'm missing?
