New control channel on CERS - 851.1250
Submitted to DB
i wonder why they changed the CC again? Good looking out!
Submitted to DB
Since putting in the new CC I'm getting some type of Fast sounding CC popping up on TG's using the voice freq of 852.0875. I have to hit scan then it goes away but comes but 5-10 min later. I don't see it in the DB for CERS or PWS.. Any ideas what's going on?It's not unusual for the control channel to rotate on Motorola systems, but I'm kind of surprised that we haven't seen this one until today. Looks like they're still working on the system.
i dont hear anything. i hear static.. with 851.1250
am i suppose to put all the frequencies listed in the DB or just 851.1250? cause i put all..
The sound you are hearing is the raw data of the control channel. You have the system programmed as a conventional system; you need to program it as a trunked system.
TG 49328 carries data for the the Auxiliary Water Supply System (AWSS), and sounds similar to a control channel. Is that the talkgroup you're hearing?
Hmm...still sounds like a problem with the scanner since nobody else is hearing it. Strange.
Very strange in deed.. The issue has gone away since about 11:30pm. We'll see if it comes back in the morning. Have no idea what kind of "interference" would cause this?Hmm...still sounds like a problem with the scanner since nobody else is hearing it. Strange.
I *think* I found the issue. I'm picking up the CC for the city of CERES trunk system off the back end of my directional yagi since the yagi is pointed west towards SF. I'm assuming the issue went away because the CC changed overnight then came back at 730 because the cc changed again to the offending freq....
That sounds right. I was going to suggest Ceres since they are the only other licensee for that frequency in California.
Problem fixed... Moved scanner 30 miles west =)
