n8myc
After being bumped around the entire house I thought I needed to go in a different direction with my equipment. I found this gem while looking in a furniture store. It weighs in at a hefty 650 lbs empty and when the doors are closed it blends right in. It has taken several months of throwing things and cussing to get it right. I had to remove the usual CD holders and useless shelves that were in there and make my own adjustments. One thing I do need to do is put a hinged peg board on the back of it, not only so it can breath but so I can get to all the wires instead of going through the 9 holes it now has.It sits proudly between the living room and dining room. There is a heater vent hole that's perfect for passing all my cables through.It's a real bear to move, takes 2 people.
The equipment is as follows. Top left and right are 2 Prima LCD monitors for HDTV,satellite TV and computers. In tmiddle are 2 BC895XLTs used for Unitrunker.
Left side is a BCT8 used for local aircraft, helo to helo, 123.025 and of course 123.45.
A BC796d used for searching out new talkgroups on the statewide MARCS system. A YAESU FT-2500M for 2m usage. A PRO-2096 for OHP posts and other tactical stuff. 3 PRO-2055s for local police stuff. On the right side is a BCT15 used for county stuff. 2 PRO-2054s used for the local trunked system inputs. An ICOM IC-706MKII for HF ham usage.
Another 2096 for use on the statewide system filled with various things. And 3 more 2055s one for neighboring police such as OSU, airport and so on, and the last 2 are split with fire dispatch and firegrounds. The Uniden 246T and Pro 95 (not shown) are my walk around the house radios. At present I'm using at TV splitter from a discone outside for 4 of the scanners. I have another to put up when it gets warm. My ham ants came down in the recent snow storm and have to be replaced. And one of my dogs hard at work watching out for my things. If you look closely you can see the discone above the satellite antennas, it's missing 3 radials that have come loose and fallen to the ground.
