ElroyJetson
Here's where I either commit atrocities or magic, depending on whether or not I am able to successfully repair a radio or not.
The pic ended up a little cropped but you can see most of what's on the bench, welll enough.
Some people love their ham shack. I love my test bench.
Guided tour, starting at top left:
Tektronix 2465B 400 MHz 4 channel 'scope
Rohde & Schwarz SMY 02 2 GHz signal generator
IFR 2024 2 GHz signal generator
Some old HP power supply that gets frequent use. Can't remember the model but it's a workhorse.
Tektronix 494AP 21 GHz spectrum analyzer with TR503 tracking generator (TG not shown)
Second row: Fluke 8842 DVM, Helper Instruments Sinadder Linear 5, Agilent E4418B RF power meter with Agilent 8498A power attenuator and E4412A wide dynamic range power sensor
General Dynamics R2670B service monitor with P25 conventional, legacy trunking, and P25 trunking options with encryption options up to AES-256.
Rohde & Schwarz FSEA 30 spectrum analyzer with option B7 flexible digital demodulation package. Probably the single most useful analyzer I've ever seen. I have two of them.
Agilent E4431B 2 GHz signal generator with flexible digital signal generation options as well as GSM and GSM EDGE options. I can generate almost any waveform and digital format you can imagine with this.
Agilent E4406A transmitter test set, essentially a specialized spectrum analyzer meant for rapid testing of cellular equipment. It is a very fast spectrum analyzer with 0.1 Hz minimum RBW capability.
Works with the E4431B together as a BERT system.
Rohde & Schwarz AMIQ 04 I/Q modulation generator, used with the Rohde & Schwarz PSL 3 industrial controller (A PC with integrated GPIB) underneath it. The PSL 3 is also my LabView controller. (A future project is to connect the whole system as an integrated test suite via LabView.)
Third row: PC, and external displays for the R2670B, FSEA 30, and the display for the PSL 3.
The AMIQ with PSL 3 gives me the capability to generate practically any digital signal (its I/Q outputs being fed to the I/Q inputs on the Agilent E4431B) and store those waveforms for rapid callup.
Some of this equipment is duplicated on the second tech bench in the shop.
I've bought, sold, and traded a small mountain of test equipment over the last few years. I've kept the items that enhance my bench capabilities the most.
There's still a lot of unexplored capability in this equipment. It can do a lot more than I'm asking it to do.
But for regular radio checkouts, I can leave most of it turned off and just use the R2670B. It's quite a workhorse.
