I have a Whistler 1040. Why are some of the frequencies shaded different colors? And do different colors mean different things?
Where are you seeing shaded frequencies? Please provide us with a screen shot or link to explain what you are talking about.I have a Whistler 1040. Why are some of the frequencies shaded different colors? And do different colors mean different things?
and want to help.
If you are talking about the database, the red frequencies are control channel capable. The lower case "c" also indicates control channel capable. They are the only ones you need to enter for a site (Minus the "c"). All of the frequency information is carried on the control channel. Are you using programming software? If you are, please attach your programming file so we can take a look at it. You will need to zip the file to be able to attach it. Click on Attach files and open the zipped file. Which systems are you trying to receive? The PA statewide trunked system is P25 Phase 2. The WS1040 is capable of decoding P25 Phase 1 only.Why are some of the frequencies shaded different colors? And do different colors mean different things?
Do you mean on the database pages?
Yellow means it has been updated in the past week. Green means it has been updated in the last 24 hours.
I use ARC500 to do my programming also. As cubn stated, an entry in the database will have a yellow background if updated in the past week. It will have a green background if updated in the last 24 hours. Do you see the colors when you look at the database or when you are downloading from the database? If you attach your ARC500 .gr5 file, I will be able to look at it and tell if your scanner is capable of receiving the systems and conventional frequencies.I am using arc500 software to program my ws1040. The shaded frquencies are when I connect to rr. I believe the shaded means that the ws1040 will not support that frequency as they are either dmr or P25 phase 2 or any other frequency that the 1040 does not support. I am fairly new to this but I want to thank those that have responded.
| DEC | HEX | Mode | Alpha Tag | Description | Tag |
| 24801 | 60e1 | TE | ACJ Control | ACJ Control | Corrections |
| 24802 | 60e2 | TE | ACJ Chan2 | ACJ Channel 2 | Corrections |
| 24803 | 60e3 | TE | ACJ Chan3 | ACJ Channel 3 | Corrections |
| 24804 | 60e4 | TE | ACJ Medical | ACJ Medical | Corrections |
| 26601 | 67e9 | T | PW Director | Public Works Director | Public Works |
| 26602 | 67ea | T | PW Foreman | Public Works Foreman | Public Works |
| 26603 | 67eb | T | PW Ops | Public Works Operations | Public Works |
| 26604 | 67ec | T | Public Works | Public Works | Public Works |
| 443.600 | 448.600 | KW3LO | RM | 10 RAN | 10 RAN | KW3LO NXDN | Brentwood KW3LO NXDN | NXDN48 | Ham |
