Hi,
I like to monitor an Edacs Networked Multi-zone or site system.
AmerenUE in Missouri to be specific.
The system has several sites and when I travel, the primary site I monitor becomes weak so I switch to one of two other sites as needed.
My problem now is that I've become interested in a StarCom system across the river that is fairly big and thus fills up the PSR-600 memory. So I'm attempting to clean things up but having an issue as listed below.
My question is, is it possible to program the three Edacs sites as seperate TSYS's but let them share the common set of TGRP ID's. The Edacs sites all share the same TGRP ID's.
I know the three EDACS sites have to go into a seperate TSYS location due to LCN ordering but I don't know if sharing of the TGRP's can be accomplished between the three TSYS's.
I use WIN500 and have programmed one site to use the TGRP's in scan list 2 which is also the TSYS id.
Now I go back and again add one of the other sites TSYS's frequencies but assign it to ID 3.
I then go into my scan lists in WIN500 and change them all to be associated with both 2 and 3.
However, I never see my talkgroups on the second system I added even though I associated the TGRP's assigned to scan list 2 with scan list 3. All that TSYS 3 shows are the wildcards but no talkgroup text tags etc.
When I programmed the first system using WIN500 and the RR database I selected all the frequencies for the primary site I monitor as well as ALL the TGRP Id's. I set the first system to Scanlist 2.
When I added the second system I just imported the site frequencies plus allowed it to create wildcards. I did not import the TGRP's again as I did not want to use up the memory by duplicating talkgroups. I set this second site to Scanlist 3.
Am I doing something wrong or does this not work on EDACS systems or perhaps a limitation in the PSR500/600?
Thanks for any advice.
