Sharing an antenna? School me.
k9-cop
OK so if I have for instance two identical UHF mobile radios can I use a T-coupler and run two mobile radios off of the same UHF quarter wave antenna?
n9mxq
Belvidere IL
As long as neither transmits.. First time one does, the other will most likely go poof.
I wouldn't take the chance.
af5rn
N. Tex / S. Fla
Yeah, you'll need a UHF duplexer, which both combines and isolates the signals so they do not interfere. Most duplexers you'll find at ham outlets are dual banders, which will not work.
k8mcn
Old Monroe,MO
If you don't want to use them BOTH at the same time , just use a two position antenna switch.install the switch backwards, so that you end up with a jumper from each UHF rig going in to one side and the antenna hooked into the single side----then you can switch rigs to antenna at the flip of a switch--- I do this here to operate two different HF rigs-just label the switch and make sure it is in the correct position (hooked to the rig you are transmitting with).
But beware--you must make sure you throw the switch--if not you will be transmitting in to a dead short (if you have a switch that grounds the unused terminal)
