Shelby county sheriff's p25 and ncd 996p2
medic9351301
Banned
Has anyone programmed this system in this radio. Do you have to enter a band plan or will the control channel decode it.
Is the information correct in the database . If I use that info. I only hear the dispatchers no units
Please help.
CORN
Nashville, TN
It shows a pure P25 Phase II system so all you should have to do is plug in the active control channel. I tried to monitor it last time I come thru there which was a while back and I guess since it was new then then wasn't much heard. Hopefully their not ENC as small municipalities like to do with their brand new digital systems.
Julian1
Fresno, TX
Shelby Co Sheriff - Radios & MDT on line to view
I had the pleasure of riding along with a deputy.
As you look at the FCC license, Harris's VHF P25-Type II digital uses 100-watt repeaters at five or so sites in the county.
Notice the mobile radios are licensed at 4-watts.
The hand held radios do not reliably reach the repeaters. SOLUTION - They use Southern Link when away from the car. Southern Link operates like a parallel system. So if they're out of the car, they are on So-Link.
ULS License - Public Safety Pool, Trunked License - WPXF230 - SHELBY, COUNTY OF - Frequencies Summary
Also - the MDT computer terminals are used a lot. Calls of any significance are on the radio, not just the computer.
http://dispatchlog.shelbyal.com >> MDT Dispatches are updated every 5 minutes or so. The time is given as: 20170412214130CD breaks down as:
2017 > year / 0412 > April 12 today's date
214130 is time in 24-hr format = 21-hr, 41-min, 30-seconds, CD = Central Daylight Time
Shelby County is a highly populated county - BUT.... the more highly populated areas are incorporated cities such as Hoover, Pelham, Alabaster, etc...
They do go back up cities on calls a fair amount too.
Hope this helps!
medic9351301
Banned
I got the system working .
It's strange the 5 freqs listed in the data base under Shelby county trunked are correct.
The fcc license freqs are not used. And the 5 are
Catorgrized as paging. This is a strange system. to say the least. Seems like they got ripped on this.
