Short HF dipole
Québec canada
My work keeps me away from home 2 weeks at work one at home my room here as one window about five feet horizontal was wondering if with a 6 or seven foot 20 gauge copper wire and a balun. Outside my window would do the job for dxing weak signals (pirate stations) I cannot set up anything else here my radio is a alinco dx-r8t
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Such a dipole would be highly inefficient at freqs at the end of the 6 Mhz (49m) broadcast band where pirates like to hang out (although they are on other bands, too...). It would work, but not very well.
How good are you with homebrewing? A Carpet Loop would be one possibility here. The other would be an antenna I built years ago, and used with a tuner - fairly effective if a bit oddball...
The Carpet Loop -- antenna special on hard-core-dx.com
The McGyver(tm) special - The RadioReference Wiki
Much as I don't like active antennas due to the fact they are more noise-prone when mounted indoors, this is a possibility;
Active Antenna 10kHz - 30 MHz
or this...
MFJ Enterprises Inc.
And finally, I'm pretty sure Wellbrook has an indoor model loop - likely that's a much better bet than a short dipole... Those are just a few possibilities. Mike
