ShawnCowden said:
WHAT IS THE BEST SHORTWAVE ANTENNAS FOR THE KAITO KA1102 SW SSB RADIO ??
`Best' is subjective. Listen to the radio with the existing antenna and see if it is sufficient for you. If not, there's a really cool, cheap wind-up reel antenna that comes with Grundigs and others. One end goes across the room and the other goes into your antenna jack. You can also accomplish this with wire and an alligator clip.
If this isn't floating your boat, it's time to Head Outside. The gentlemen who posted about Windoms had the right idea, afaik. One thing to consider is that you're a LISTENER, so you don't need high-power tuners, etc.
Since antennas are just wire, why not throw up some wire? Try the Windom idea - I'm told you don't even need the balun (I don't use one).
An even easier route would be the end-fed antenna. This simply means you run a wire from your radio to the antenna end, then string the antenna. Get it as high and long as you can. Run the center of your coax to the antenna and the shield to a ground rod, driven into the ground (buy at Radio Shack). The ground isn't mandatory, but it can certainly help a lot.
Hell, you can throw a wire coat hanger up on the roof with enough wire attached to make it through your window and see if that works.
If you're interested, there is a LOT you can learn about antennas. If not, try things until you're happy with the results.
I don't have any of the active antennas but I'm told that they can overload more sensitive receivers.
Good luck!
