Shot in the dark antenna question
Josh380
Orange County, CA
I had a base station antenna back in the 90's that I can't recall the name of..hoping someone here might know the name.
I remember it being made of aluminum, and in a few 8ft sections that basically were telescoping pieces. You'd usually mark it at each section with a sharpie once you had your best SWR.
I might be describing an Antron 99..I'm not sure if that's correct or not. I do remember it being a great base antenna and would love to get my hands on another.
prcguy
Need a lot more info. How tall? Ground radials, if so how many, or small ring at the bottom or none or?? Any attachment on the top like little wires, loops, etc?
n5ims
Base station..for...CB? HF? 2m/440?
Since this is the CB forum, I'd go with that as your starting point for any answers. If they posted to the wrong forum, then they'll get answers that aren't what they're looking for and request a move to the correct forum.
wowologist
Certifiable
CM87
We'll here were probably the most popular at the time and I think they ran that line until the mid 90's for CB base station. Then I think they added 2 more from what I think were at the time rebranded/reboxed Regency which were rebranded from someone else...This is of course if it was a literally mass produced for the masses antenna...that could be bought at the local shack.
Josh380
Orange County, CA
This would be for a CB. Hard to say how tall it was..there were at least 3 sections that I believe were 8 ft in length so 24 ft or less (for SWR). No radials.
prcguy
Was it just a smooth aluminum pole with mounting bracket or did it have a 1ft across aluminum tuning ring at the bottom like the attached picture or any other parts that might identify it? What did the mast mount look like?
Nope. This was all aluminum, from coax connection to tip. According to a Google spec search, the Solarcon IMAX 2000 is fiberglass.
Josh380
Orange County, CA
Was it just a smooth aluminum pole with mounting bracket or did it have a 1ft across aluminum tuning ring at the bottom or any other parts that might identify it? What did the mast mount look like?
Smooth aluminum, mounting bracket at the bottom (see previous reply)..similar to a walkie talkie telescoping antenna but on a much larger scale. No tuning ring. SWR was adjustable at each section by telescoping down or up, depending on your SWR.
prcguy
Just a comment, any antenna like this with no ground radials or decoupling would be, well, basically a piece of sh*t antenna. Its fun to identify what you might have used years ago but an antenna like this is not worth pursuing unless for sentimental value. You can get a much better performing antenna for not much $$ these days.
Josh380
Orange County, CA
Eh..that may be. I seem to remember having a good SWR with it..my stepdad had one at his cabin and I was talking skip to Tennessee like he was right next door with only 25 watts. Granted that was in the 90s when conditions were a little more favorable, but it did the trick.
