Should I be able to hear Sacramento police?
jfalk
I am in Woodland .My discone antenna is on a long pole on top of a a 2 story home.
I have a 996t scanner.Have yet to even here a whisper.thank you
gmclam
Fair Oaks, CA
Yes. I pick up the SRRCS all the way to Orland (and perhaps beyond) when mobile. You should program site 012. I'd try ID SCAN until you hear conversations and then go from there to program desired TGs (and switch to ID Search).
tvengr
Well Known Member
Baltimore County, MD
What is your squelch setting? Discones are not the best antennas for 800 MHz. With the antenna up high, 17 miles may not be too much of a reach. Simulcast distortion is usually less of an issue when you are some distance away rather than surrounded by towers. What programming software are you using? If you attach your programming file, I will check it for errors. You will need to zip the file to be able to attach it. Click on Attach files and open the zipped file.
jfalk
Thanks for your reply..I have an older scanner BCD996t,ID SCAN sounds good.Do I even have it?
jfalk
I'm trying to use Freescan and a YouTube
Video.I'm close to chucking the scanner out the window.
I'll figure out the file to send, straight out of Radio Ref tomorrow.I do know I only downloaded the control channels.
Appreciate your help
wtp
Port Charlotte FL
you really want the radio to be scrolling ID SEARCH.
that means you will catch anything on the system
id scan is to scan only the talkgroups you have selected.
and squelch should be at 2.
easy to read manual
hard to read manual
also some systems have their antennas pointed down into the area of coverage.
it helps to reuse the frequency/s closer.
so it might just be impossible to receive them at all.
and if your coax has been in the weather for more than five years, it might be time to replace it.
jfalk
Not sure if I did that right,sure appreciate the help.
  • SacramentoRgnalR.zip
jfalk
easy to read manual
hard to read manual
Nice of you..I am taking your advice and reading abit first.
  • Like
Reactions: wtp
billcurrie
WD0EHJ
Rio Vista, CA.
You should be able to receive both the Davis and County Wide simulcast repeaters from Woodland. I'm using a 996XT in Rio Vista with a discone and get full scale from both repeaters. Good luck with tracking down the issue.
tvengr
Well Known Member
I don't see any obvious problems with the programming. I suspect it is either a signal strength or simulcast distortion problem. Try turning the squelch fully counterclockwise to open it. It's about time to load up the scanner and take a ride to Sacramento to see if it works. Are you able to receive your local Yolo County site and talkgroups? Do you see the control channel frequency or NFM on the 4 sites (above quick keys on scanner display)?
jfalk
Yes the woodland police comes in just fine. 155.000 would that be VHF?
That's a great idea, I will be taking the scanner to Sacramento real soon.
There is no control channel frequency or otherwise when it scans. Thank you for looking at my download
tvengr
Well Known Member
I55.055 is a VHF conventional frequency for Woodland PD. Do you receive any of the talkgroups for Yolo County on the trunked system? The Davis site is simulcast. If you see NFM and not the control channel frequency for the site, try disconnecting the outside antenna and use the back of scanner antenna. You can also try turning on the attenuator. When dealing with simulcast sites, less signal is better.
