I installed a Wilson 301111 (N-Female termination) in the attic, and due to pathway issues I can't run LMR400 (the stink pipe makes a bend, so there's no straight shot to the basement).
So I've settled on going with Belden 9913 (RG-8 Low Loss) which I plan to order from the Antenna Farm and I'm going to request them to install a Male N-Type on the antenna end... but the question is, what should I terminate to on the device end?
The plan right now, is just to hook it to a scanner.
In the future I might try to leverage the cable run with some kind of discone all band antenna - and use a multicoupler to share the run with multiple scanners.
I'm leaning towards going with BNC Male at the other end, but I figured I'd check with all of you.
