Shoutcast for streaming
AB5ID
Lee's Summit, MO (Kansas City)
Can I configure Winamp with the Shoutcast plugin to stream directly to my RR/Broadcastify account?
I have an old Pentium I'd like to use with Winamp and audio processing plugins.
I've had trouble finding a clear answer.
Thanks in advance,
Steve
Scan-Denver
Denver, CO - USA
Does it have to be Shoutcast? There are several alternatives listed here you can use.
The streaming software listed above will grab the audio from your computer and stream it to Broadcastify. So even if you need to use Shoutcast, the audio from your computer would be used to stream to Broadcastify.
I'm not 100% certain and if someone can clarify that would be great, but I do believe streaming directly from Shoutcast, you will need to also use another software to be the bridge between Shoutcast & Broadcastify.
If using the audio from Winamp which is accessible directly from your computer is acceptable, then the streaming software listed above will do the job. I personally use RadioFeed which works very well for my feed.
