Shuttle launch
luke-1
Parker, CO
Does anyone know the ham Freqs. for the shuttle launch, in the Rockford area?
Luke
K0ATC
Oklahoma
Hey, I'm over in byron. If you can get into an IRLP machine try reflector 9356. If you can monitor HF, 14.295 will be a good one to listen to, it will also have some air to ground UHF rebroadcasts for a short time. Heres a link to check out for the HF stuff:
http://home.flash.net/~av8tor/radios/shuttle.htm
Reguardless of what people say there are rebroadcasts of UHF air to ground comm's, then they switch over to S band digital sat comms.
