BC785D: SICK SCANNER
brey1234
Banned
Pennsylvania
I have several scanners including a Uniden which is sick.--it's a thousand channel----bc 785---Most channels are programmed, via software, to have a 2 to 4 second delay---BUT when a transmission is heard it always starts scanning before the transmission is complete---Any ideas? Checked the programming and it shows the channel and the delay function is enabled.
If I ship it back should it be to Uniden or someone who specializes in scanner repairs?
fxdscon
¯\_(ツ)_/¯
Check page 32 of the owner's manual, sounds like you have set a "negative" delay, which would cause exactly what you are reporting.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
That's exactly the sort of behavior it would exhibit if a negative delay was set. Does this scanner support that?
Mike
