signal indicator
troymail
Silent Key
Is there a known reason why while scanning a given system (single CC / site) the Uniden radios seem to "drop" lock on a regular basis (as seem from the signal strength meter bars) while scanning but does not do this when you are paused/holding onto a talkgroup?
I think I recall seeing this on my 396T also and never understood why.
As far as I know I have no priorities of any type enabled so that's not the reason.
What is the scanner looking for when it (apparently) releases and then acquired the CC when there is only one CC/site active?
KevinC
Other
Home
This is all UPMan has publically told us...
http://forums.radioreference.com/un...ically-monitoring-one-system.html#post2075871
nd5y
Wichita Falls, TX
From what I can tell on the 396T nothing else is happening.
Either they made the S-meter flash on purpose while the display is showing ID SEARCH and ID SCAN or it is a minor firmware bug.
KevinC
Other
Home
Thanks Kevin.
UPMan - does the radio drop the CC lock when this happens (thus it has to reacquire it each time)?
I'm pretty sure it does, I'll try to confirm this later today.
If you change the "Hold" time to say 10 seconds the "housekeeping" drop out should occur on that interval.
