jody_clarke
Greetings everyone and thanks for checking out this thread as I need a bit of expert advice as I'm nearing the end of setting up my little Rx'ng antenna system. Here's a bit of background info- Thus far I've purchased a Diamond D-130NJ discone along w/ 85 foot of LMR-400 coax. Before I ask the two questions I have for you guys(the latter question being somewhat absurd) let me give you a quick run down of my geographic situation as well as what I'm trying to pull in- I live in a very (we call them mountains down here- although they are actually very large hills as I've traveled enough to know what true mountains look like) so very hilly terrain, and happen to live at the very base of one of these very large hills in a very steep valley with a very large hill directly blocking the South- South Eastern view as we are surrounded by trees & lots of them.What I'm attempting to monitor is approx. 20 miles l.o.s.-if I had a clear l.o.s. to the majority of transmitters(mostly Public Safety 155MHZ some VHF-low Electric-coop,, as well as some 440MHz.)
First question- Now that I've finally got my antenna and coax I'm starting to doubt my decision about using a jumper cable- if you read my geographical information you can understand signal loss concerns of ANY. The coax is an 85 foot run of LMR-400 with an N-male connector to antenna to a male N connector. The jumper cable I'm referring to is made up of 6 feet of 9913 with a N-female and a BNC to radio. The only reason I went with a jumper cable to begin with was this cable run is for a handheld. Although in the past I've ran RG/8 to a handheld and simply laid it on it's side- no biggie. Guess what I'm getting at (not that it matters but connectors are at least heat shrunk) is even with my using the stretchy splicing tape along with quality 3M 33+ electric tape to wrap and fully( to the best of my ability) insulate the connectors could anyone give me any idea as to how much signal loss I'm looking at using this jumper cable, as mentioned I could get an LMR-400 BNC connector and have someone put it on the LMR-400 directly. Realize no one can tell me exactly how much loss I'm going to incur but any ideas .5db's, 1db, possibly more?? Any estimates, guesstimates, or suggestions on this would be greatly appreciated!!! One other quick question related to signal loss is the Times Microwave LMR-400 grounding kit were you have to strip 2 inches of the coax jacket, attach grounding kit and tape back up correctly, If done correctly how much signal loss can I expect from this?, while I realize all these things may be minimal in and of there-selves seems to me that eventually that they're bound to add up -.5 here, -.25, her, -.75 there, -1.2 db's for coax run-before I know it
there goes half my signal? Is the grounding kit necessary, I've read how important it is to ground your antenna/mast-but coax? Maybe I simply don't know- not to take away from my previous question-Thanks, for anyone's input!!
Secondly, I know the deal the higher you can get your antenna the better- yet there's always the trade off w/ length of coax. Have a fairly good idea about this but figured I'd ask to ensure I was correct? Considering my geographical location wanted to ensure this remains the same, although I somehow doubt the fact that I live in a deep valley anything would change my guess given the area I live in the more height the better regardless of how deep of a valley I'm in but wanted to double check w/ the experts, as I'm always tend to over think such simple matters and realize my living in a hole doesn't change the laws of physics. Guess my question would be (considering my geographical location) is getting my antenna about 10 feet above apex of roof (40 feet from ground)- saving about 20 foot of coax from my originally planned 85 foot run & placing antenna up to 20 feet above roof apex- 60 ft. from ground a better option or would I be correct in my assumption that regardless of how deep of a hole I'm in the higher the better particularly in my situation? As mentioned I tend to over think these things and I've yet to purchase my mast/pole So please don't blast me for asking what to most will sound and most likely is a ridiculous question-Thanks for your patience!
Just Curious:For some reason w/ a mobile mag mount on peak of metal roof I'm able to receive NOAA WX radio out of Birmingham-due South blocked by huge hill directly across a (creek/ finger off of very large lake)-approx. 30 yards South of house) and approx. 45 miles l.o.s. stronger than I can receive NOAA WX radio out of Huntsville @ approx. same distance due North both broadcasting @ 1000 watts? -Realize this could incorporate many factors mostly geography, simply curious if anyone might have any specific ideas.
