I'm using a Uniden BCT15X exclusively for reception of AM VHF/UHF aircraft. I'm using a diamond D130J N discone antenna mounted on a 9' tripod inside my home office. Almost without exception I get full 5 signal strength bars every time the scanner breaks squelch. The odd thing is about half the transmissions are very clear with very little noise, almost full quieting but the rest are accompanied by static. Is this due to weak audio modulation from the transmitter or something else? I'm considering trying a preamp but if the signal is good, would it help or make the noise worse?
I should mention I'm also using a Stridsberg FM notch filter. The frequency does not appear to matter.
Thanks!
Thanks!
