Signaling
Eg8452636763
spring valley new york
Hello,
I Have an issue while programming an XPR4550 (VHF).
I am trying to get the option of Signaling Squelch to be "AND" with a proper MDC group but it's grayed out.
Would anyone know what could be causing that?
Signaling Squelch Grayed out
Tech21
You realize frequencies are re-issued and used by several thousand people and agencies across the country. There is no reason to blur it out. Don't need to do that with the signaling system either seeing as it doesn't give away any identifying info unless it's named "MAYBERRY SO, SHERIFF ANDY TAYLOR, BADGE NUMBER 0100."
Is your MDC system set up properly?
Is your receive/transmit signaling system set to something other than "none" in the channel?
