Signalink and CDM1550 LS+ Zello@Work
Bedford, Kentucky 40006
I'm running a Motorola CDM 1550 LS+ with a Signalink USB via 16 pin accessory port for 911 Communications via Zello@Work, my only continuous issue I'm having is the audio varies user to user some users audio is lite others are so loud their distorted. Haven't been able to figure out why the audio varies user to user when the configuration never changes
Anyone have any ideas or similar issues? Currently finishing a trial with roxi but due to almost $175 cost difference not sure which way EMA/County will go
a417
Audio varies in which direction in the signal chain? Zello to radio? Zello to zello? Radio to Zello? @jeepsandradios has a very good point, lets make sure you are always giving the ROIP interface the same flat audio.
KC3AWP
Lycoming County, PA
I would also point to the radio. We are currently using Zello Work with a SignaLink attached to a NX700 and its been working well for us for about 2 years. Orban has a free meter that you can use to see the output levels you are putting into your application. just google orban loudness meter.
DuaneN
Did anyone or can anyone do a quick writeup on using a Signalink for Zello and a CDM radio? What software changes , if any, are required for using the 16 pin connector? any tips and tricks are appreciated!!
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
I would swap from CDM to a MOTOTRBO with analog RX audio leveling enabled only if flat audio does not work. TT
