Simple Question
rochele1
Hi ,
when i put my motorola radio close to my computer it has effect on monitor and mainboard , is there any material or something to protect my PC , imagine i must put the radio beside computer and there's no more option
jeepsandradios
East of the Mississippi
Where is the antenna ? Antenna should be out side and not next to the radio. As long as your antenna is mounted properly and the correct antenna you should see no issues on your computer. I actually have an APRS computer with the a radio mounted in the CD slot with no issues to either.
When transmitting, or receiving?
When transmitting, this is understandable. The RF from the transmitter gets into the PC and monitor and will cause issues. Better shielding on cables and housings can help, but it would be difficult to fully eliminate. Best solution is to not transmit when close to your computer.
If it's when it is receiving, then likely the local oscillator frequency is leaking out and getting into the PC. I've never had a radio do this while receiving.
rochele1
Antenna is about 2 meters far from PC ,
and my question is that what kind of shielding i have to look for ? , is there any specific name or expression ?
popnokick
Northeast PA
Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 7_0_6 like Mac OS X) AppleWebKit/537.51.1 (KHTML, like Gecko) Version/7.0 Mobile/11B651 Safari/9537.53)
Get the antenna installed OUTside the building you are in and well away from the computer.
jeepsandradios
What he said. Antenna needs to be out side the building and not near you or your computer. Improper antenna installation will cause not only issues with nearby electronics equipment but also damage to the radio. My guess is the Magnetic mount you are using needs replaced with a real base radio antenna on your building/
MTS2000des
5B2_BEE00 Czar
Not trying to be sarcastic, but this is why a professional should be involved with installing high powered radios. RF power levels generated by mobile and fixed base radios can be dangerous to not just other equipment but people as well should they come in contact with the antenna.
