Simple question
seagullplayer
Marengo, IN
I have listened to short wave off and on sense I was a teenager.
Right now I have a couple of radios, one is a button pusher and one is a knob turner.
Seems like I always find something interesting then it fades out on me. I know this is just the way it works, but I really think a decent outside antenna would help. (both radios have inputs for antenna and both have portable antenna on them)
I have tried making my own, but have always been disappointed in the result. I would like to buy something, but last time I asked in Radio Shack they acted like I had two heads.
Where do I look? I don't get to listen often, I get up way to early for work to be up very late listening to the radio. So I don't want to break the bank of something I might only use a few times a year.
I would consider making my own again if someone had an idiots guild to a fool proof design!
Thanks,
ridgescan
San Francisco, Ca.
How much wire can you run? You can draw ideas from my experiences here. I am in an apartment and when I ran a wire antenna, I ran up to 100' at one point. My best reception came from a 75' random wire oriented n-s/e-w, it was grounded at the feed to the building's fire escape which itself was bolted to the building I-beam frame which fully quieted MW. I fed it at one end through 50 ohm coax which was grounded at the shack which knocked a couple s-units noise out at HF.
I had a 9-turn coax coil choke right at the feedpoint that quieted even more at HF.
$28 for #12 solid copper wire at Lowes, $30 for the LMR240 coax run, $78 for the PAR ef-swl.
I ran my own wire off that PAR transformer box, but I bet, for the reasonable price of it, you'd do great with just buying the PAR ef-swl and use their 44' supplied wire. The main point I wanted to convey is to ground it so that endfed wire can work against a counterpoise.
Universal's selling it for $72 now:)
Par Electronics EF-SWL End Fed Dipole SWL Antenna. Par EF-SWL.
Boombox
The "button pusher" I'm guessing is a digital portable.
Just re-read your post, you said you tried an external antenna but wasn't satisfied with the results.
Try a longer antenna. You may need one that is longer than the one you already tried.
I have a couple digital portables and I get very good reception on a 20 ft. indoor wire. But I did get better reception on a 100 ft. outdoor wire that blew down a few years ago.
So try a longer one, which you can make with any wire -- even stripping speaker cable in half can give you enough wire for an outdoor antenna.
Try 30-50 feet or so, if you have the room for it. See if that helps. Make sure you disconnect it and ground it if there is a chance of lightning or T-storm activity, or if it's dry in winter (static electricity buildups aren't good for radios RF sections).
Good luck.
majoco
Stirrer
New Zealand
...and connect the wire to the proper antenna terminal on the radio - not to the whip.
