You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
RadioReference.com Forums
Just thought I'd make this stuff easier to find ...
If your receiver has a lot of hiss, or the filters are very wide, you may want to roll off the high end frequencies with a simple resistor / capacitor combination.
I've done this to various rigs to suit my taste. The basic stuff can be found here:
TIP: If you have never done this, when you clip off the leads after soldering be SURE to have a firm grip on the lead with some pliers, otherwise the lead will get sucked into the speaker magnet, and forever buzz. Or, you attempt to retrieve it, but poke a hole in the speaker itself. Ask me how I know!
Also don't be in a rush and put the capacitors on the wrong side of the resistor...
