- Joined
- Jun 13, 2018
- Messages
- 869
Ah !, no, not a scolding Joel... I just fear Val is getting overwhelmed by too many esoteric suggestions...
by -the-by---Below is the FCC rules that apply to LowFer'ing, as its commonly known--
15.217 Operation in the band 160–190
kHz.
(a) The total input power to the final
radio frequency stage (exclusive of fila-
ment or heater power) shall not exceed
one watt.
(b) The total length of the trans-
mission line, antenna, and ground lead
(if used) shall not exceed 15 meters.
(c) All emissions below 160 kHz or
above 190 kHz shall be attenuated at
least 20 dB below the level of the
unmodulated carrier. Determination of
compliance with the 20 dB attenuation
specification may be based on measure-
ments at the intentional radiator’s an-
tenna output terminal unless the in-
tentional radiator uses a permanently
attached antenna, in which case com-
pliance shall be demonstrated by meas-
uring the radiated emissions.
It is a band for serious nut cases...laffing... but not for any serious communicators
kHz.
one watt.
