simplex problem tyt md 2017/ md 380
tonym5793
I have the md 380 and md 2017 both using the same code plug with the conversion software for the 2017 I cant not receive audio on either radio when transmitting simplex from either radio I do get the green receive light on both but no audio my settings are,,,,,admin channel free--contact local TG9--CC 0--slot 1--group none...I have changed settings and have watched many vids any ideas on this please,,thanks Hopefully I have posted in the correct area....
I would change the talk group number from 9 to 99 and from CC 0 to CC 1..That way you could be standardized across the board with all simplex operators...
Here's a link for your reference..
http://www.va3xpr.net/dmr-simplex-frequencies
On a side note, there is a YouTube recently uploaded were an individual having issues with the MD 2017 antenna. It appears as the antenna on it does not work. I don't remember if it was in UHF or VHF. You may want to check it out. I would try another antenna on the MD 2017 and see if your particular unit has that issue.
tonym5793
Are both radios using the same MARC ID number?
Hello each radio has its own ID number from MARC.......so far the antenna has been ok as I did hit other repeaters in the Boston area while on a hike,,,Thanks I will make those changes,,,,,,also thanks for the link....
KE5MC
Lewisville, TX
If the changes don't help, try setting both radio to there lowest power setting. Separate the radios as far as possible and lastly if you have a dummy load transmit into that.
Its possible you are overloading the receive radios frontend.
Mike
tonym5793
hello I did make the changes and did separate the radios and still no audio on digital simplex but I did find that analog simplex did work ok ...md 380 and md 2017 using same code plug with the conversion software for the md 2017 ....am a bit lost on this one,,,thanks
Try creating a new cps for the MD 2017 with just the simplex channels and try then. The problem may be with the so called conversion.
DMR Simplex Frequencies
Hi
Yes I think I know what video you are talking about saying he cant hit a repeater with the antenna that came with the MD 2017.
I have kinda the same trouble when im in my room no matter what. The green light will flash meaning its getting info/talk.
When I get closer to the front door or outside things are better..
When I tried to convert the MD 380 code plug to the 2017 I would get a bong no matter what channel/zone I try.
I dont know what setting messed up.
73
Michael
eaf1956
Evansville, IN
The latest firmware for the MD 2017 addresses an issue with the rec and trans freq being the same.
Narpho
Huntersville, NC
Same type of problem
Has anyone figured this out. On my MD2017 the DMR and UHF work fine. VHF Simplex works but I cannot hear audio back from repeaters. Tried different antennas, no luck. Funny thing is I had a long QSO last night on a VHF repeater without a problem.
chief21
Summer - Western NC; Winter - Tampa Bay FL
Double-check your receive frequency and RX mode for each of the affected analog channels. Be aware that most ham repeaters do not use CTCSS tones on the outbound frequency. If you have CTCSS/DCS decode set on an analog channel, in most cases the repeater audio will not pass.
John AC4JK
tonym5793
uhf simplex problem md 2017
Hello I did make a new code plug with just one digital uhf simplex freq and it worked so I deleted the ones in the 380 code plug after the conversion for the 2017 and re-entered them and it now works fine..the VHF digital simplex ones worked fine without having to delete and re enter,,,,,Thanks
So that could mean that the conversion method is not working correctly at this time. I don't have version 1 of this radio, so I can't verify for myself.
