Simplex Repeater
FARMER522
Does anyone here use a simplex repeater if so what brand and how well do they work? I found a few but don't know how well they work. I have been wanting to try one on a Kenwood mobile but wanited to see if anyone here uses one. Thanks
WayneH
Forums Veteran
Super Moderator
Sitting in an airport somewhere
Thread moved. The Other Receivers forum is for devices that receive-only. Transmitting devices should be placed in their respective forum such as one of the amateur ones, GMRS or one under Commercial and Professional. Thanks.
firemedic2150
Senior Member
Right here...
I used one years ago made by Zetron that plugged into a Maxtrac and they supplied the cable as well. This unit was neat in that it had a simplex phone patch as well.
MMc.
stevelton
As long as they are setup correctly, and the users arent holding really long conversations, it works well.
We had on for our EMA last year, on a 250 tower!
I would recommend having different PLs on the tx/and rx channels, so that the others listening dont hear you talk, and then hear you talk again through the repeater. This would also have the benefit of having a "talk around" channel that did not have the PL needed to get into the repeater, if you were close enough to the other person not to need the repeater.
Steven
FARMER522
Steven
stevelton,do you know what kind or brand of repeater your EMA was using? Was it hooked up to a mobile or portable radio? I also think that is a good idea about having different pl tones I didn't think about that.
